GCCISarah Posted May 1, 2019 Share Posted May 1, 2019 Hi all, All mirrors from the catalog(s) that I am placing show a bright yellow cast and pixels on the reflective surface of the mirror itself. The mirror IS reflecting the room around it, but the bright yellow color and pixelation never resolves itself. The first photo is the 'Standard' camera view rendering technique, where the yellow is at its brightest. The second attachment is 'Physically Based' rendering technique, where the yellow is faded a bit. I had no problems in X10, but this issue has been in all of my plans so far using X11. Any thoughts? The mirror material is set as a 'Mirror', with 100% reflection. I've not changed any defaults, preferences, or qualities about the mirror material or camera views that I could think would affect the reflective quality. Help appreciated. Link to comment Share on other sites More sharing options...
Chopsaw Posted May 1, 2019 Share Posted May 1, 2019 This seems to be specific to your template or computer setup. You could post a test plan file that is showing the error and let us know a little more about you video card and driver version. Link to comment Share on other sites More sharing options...
Greg_NY61 Posted May 1, 2019 Share Posted May 1, 2019 I agree with the above, something is not right with set-up or most likely your video card. Post that plan so we can open it here and try it on our systems. Here is a mirror from the library Link to comment Share on other sites More sharing options...
Gentoo Posted May 1, 2019 Share Posted May 1, 2019 I had exactly the same error. I installed the most recent driver for my Video Card and the problem was solved. Link to comment Share on other sites More sharing options...
