CarpentersMill Posted April 24, 2019 Share Posted April 24, 2019 I've been able to draw everything a designer has thrown my way except for this angled shelving wine storage cabinet (see picture). Working with CA Interiors X11 is it even possible to draw something like this? I just don't know how to do the angle on the shelving or if that is even possible in the program? Any help would be much appreciated. Wine Shelving.pdf Link to comment Share on other sites More sharing options...
solver Posted April 24, 2019 Share Posted April 24, 2019 Polyline Solids? Sloped Soffit? Link to comment Share on other sites More sharing options...
CarpentersMill Posted April 24, 2019 Author Share Posted April 24, 2019 Sorry Newbie here. I've only had the software for about a month and a half. Mainly used for cabinetry design. I haven't used polyline solids yet. I was curious if there was a way to do it in the cabinet part of the software easier than drawing a polyline solid. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 24, 2019 Share Posted April 24, 2019 6 minutes ago, CarpentersMill said: Sorry Newbie here. I've only had the software for about a month and a half. Mainly used for cabinetry design. I haven't used polyline solids yet. I was curious if there was a way to do it in the cabinet part of the software easier than drawing a polyline solid. Make the cabinet as usual , then make one PLS in Elevation View and copy it and set different heights for each Shelf.... One of the cabinet Gurus may have a better Idea....... Mark where are you @MarkMc Do your SIG. Please............... Link to comment Share on other sites More sharing options...
CarpentersMill Posted April 24, 2019 Author Share Posted April 24, 2019 I guess that's true... I was thinking of making the whole shelving insert as the PS and that was a bit too much for me but one shelf and copy would be a lot easier and I could use it on other projects and modify the design as needed. Good idea thanks! Link to comment Share on other sites More sharing options...
MarkMc Posted April 24, 2019 Share Posted April 24, 2019 Make one, convert to a symbol-fixture interior,look at the height setting of the symbol bounding box- make note. Cabinet, front is opening, specify shelves, manual. Number of shelves so that the spacing shows equal to or less than the height of your symbol (at least to begin with). While in shelv dialog -library, select your shelf symbol, apply to all shelves, change shelf depth if need be. You would want to make a nicer symbol than I did here so ends match cabinet angle. May need to have a play with it when changing sizes or may need to make another symbol (save the plan and you can do that quickly. Copy the original symbol and paste in library, open symbol, flip it, rename it. Then you have both. Simple fast plan attached. Angled shelves.plan Link to comment Share on other sites More sharing options...
CarpentersMill Posted April 24, 2019 Author Share Posted April 24, 2019 THANK YOU! I knew there was a way to do it but I think I've just spent too much time on the computer overthinking it. Seriously you're amazing thank you! Link to comment Share on other sites More sharing options...
Kbird1 Posted April 24, 2019 Share Posted April 24, 2019 12 hours ago, MarkMc said: Make one, convert to a symbol-fixture interior,look at the height setting of the symbol bounding box- make note. Cabinet, front is opening, specify shelves, manual. Number of shelves so that the spacing shows equal to or less than the height of your symbol (at least to begin with). While in shelv dialog -library, select your shelf symbol, apply to all shelves, change shelf depth if need be. You would want to make a nicer symbol than I did here so ends match cabinet angle. May need to have a play with it when changing sizes or may need to make another symbol (save the plan and you can do that quickly. Copy the original symbol and paste in library, open symbol, flip it, rename it. Then you have both. Simple fast plan attached. Angled shelves.plan Nice !...... Thanks Mark , I figured you'd know a way to persaude the Cabinet DBX to do as you wanted it too ....thx for the plan too... Link to comment Share on other sites More sharing options...
Xbox123 Posted October 15, 2021 Share Posted October 15, 2021 After I downloaded MarkMc's file, I was able to twist the angle shelf to make a WINE CUBE. I think Chief has to make flexible wine rack to play around with columns and rows like KCDw. Anyway just unzip & enjoy! PS: Those who decides to download, do NOT change the file name. 18x18 Wine Cube & Bar - TEMPLATE.zip 2 Link to comment Share on other sites More sharing options...
