Michael_Gia Posted April 19, 2019 Share Posted April 19, 2019 Hi again, What controls the boxed eave construction? I created a double fascia by adding a shadow board. Now my boxed eave doesn't come all the way down leaving a gap. Also there is a space between the fascia and shadow board. How can I close this up? Link to comment Share on other sites More sharing options...
Evolution Posted April 19, 2019 Share Posted April 19, 2019 Michael, I'm a long ways from being an expert or knowing exactly what to do, but what I did do was change the width of your fascia board to 7 1/4". It seem to fix the gap ok, and I didn't see any negative reaction. See if that is what you are looking for. I was trying to save the plan and send it back to you but not sure why I can't? Link to comment Share on other sites More sharing options...
Michael_Gia Posted April 19, 2019 Author Share Posted April 19, 2019 Yeah, I was able to close the gap between the Shadow board and the fascia as well by changing the vertical offset to 5.5". I had mistakenly set it at 6.25" for some reason. The boxed eave gap on the front gables is still a mystery. I've tried quite a few setting changes with no success. I can always slap a p-solid on them, no big deal, but I'd like to understand if these boxed eaves are controlled somewhere. Link to comment Share on other sites More sharing options...
HumbleChief Posted April 19, 2019 Share Posted April 19, 2019 Adjust your eave fascia and your eave sub fascia the same. You're seeing the difference between those two settings. Link to comment Share on other sites More sharing options...
Michael_Gia Posted April 19, 2019 Author Share Posted April 19, 2019 If I set my eave fascia to 11" (2x5.5") then this closes up the boxed eave nicely but then I loose my shadow board. Link to comment Share on other sites More sharing options...
HumbleChief Posted April 19, 2019 Share Posted April 19, 2019 Try setting your eave fascia to 10 13/16. Seems to work OK here, shadow boards and all. Link to comment Share on other sites More sharing options...
HumbleChief Posted April 19, 2019 Share Posted April 19, 2019 You also might have your gable fascia and shadow boards reversed. The 5 1/2" gable fascia is acting like a shadow board and your shadow board is behind it. Nice look actually and maybe what you want. Here's what it looks like with these settings. Link to comment Share on other sites More sharing options...
Michael_Gia Posted April 19, 2019 Author Share Posted April 19, 2019 If I do that then I loose my double fascia on the front of the gables. I can't seem to get the double fascia and a nicely closed up boxed eave on the front. P-solids to the rescue. Unless there's a smarter way to use a frieze instead? Maybe reverse the order of the shadow board? That is, a shadow board and offset it to act as the fascia. Link to comment Share on other sites More sharing options...
HumbleChief Posted April 19, 2019 Share Posted April 19, 2019 I must be missing something. I set the eave fascia to 10 13/16 and it closed up the box with no further adjustments or change to the shadow gable fascia look.. Link to comment Share on other sites More sharing options...
HumbleChief Posted April 19, 2019 Share Posted April 19, 2019 Link to comment Share on other sites More sharing options...
HumbleChief Posted April 19, 2019 Share Posted April 19, 2019 Good luck, let us know how you solve it. Link to comment Share on other sites More sharing options...
Michael_Gia Posted April 19, 2019 Author Share Posted April 19, 2019 On 4/19/2019 at 8:57 PM, HumbleChief said: Good luck, let us know how you solve it. Expand Hey thanks for the exploratory video. That’s right the gap I’m trying to fill is the front boxed eaves on those gables. I don’t have a problem with closing them and maintaining the double facia on the front of the Gables but then I lose the double facia on the side just adjacent to those boxed eves. You did make me rethink how I’m using the shadow board. If you notice I have it set back with a negative value. That’s because this is how we build them up here in Montreal. When we build a double facia we always leave the main facia where it is as it comes in from the truss manufacturer and then we tack on a second 2 x 6 to the back of that facia. This is why I have my shadow board behind the facia in Chief Architect Link to comment Share on other sites More sharing options...
HumbleChief Posted April 19, 2019 Share Posted April 19, 2019 On 4/19/2019 at 9:10 PM, Michael_Gia said: Hey thanks for the exploratory video. That’s right the gap I’m trying to fill is the front boxed eaves on those gables. I don’t have a problem with closing them and maintaining the double facia on the front of the Gables but then I lose the double facia on the side just adjacent to those boxed eves. You did make me rethink how I’m using the shadow board. If you notice I have it set back with a negative value. That’s because this is how we build them up here in Montreal. When we build a double facia we always leave the main facia where it is as it comes in from the truss manufacturer and then we tack on a second 2 x 6 to the back of that facia. This is why I have my shadow board behind the facia in Chief Architect Expand VERY interesting, thanks for clarifying that. If the shadow board is in the front and set to both eave and gable, zero offsets, it will wrap around that lower portion of the box and give you your double fascia there, if that's the look you're after? Link to comment Share on other sites More sharing options...
Michael_Gia Posted April 19, 2019 Author Share Posted April 19, 2019 Perfect! Thanks a million. I guess I’ll simply set the roof overhang back the thickness of the shadow board so that the dimensions to the front of the shadow board indicates my desired overhang. Credit to Chief for even having this many features attached to a roof. Link to comment Share on other sites More sharing options...
