Cut wall on angle above roof line
verticalworks
Justin, you will need to do a Poly line solid after you build the parapet condition you want. The help video is for building a parapet using poly solid, and although it doesn't address your particular need it does give great info on how to use the tools, so you should be able to apply the principal to achieve what you're after. I used Poly line solids to build a special size parapet on three walls of a single sloped roof I had on a project. Worked ok. There might be other ways, I don't know.
www.chiefarchitect.com/videos/watch/1531/creating-parapet-walls-using-polyline-solids.html
Give it a try and see if this works for you.
    31423
    jomax77
    jomax77
