ACADuser Posted April 17, 2019 Share Posted April 17, 2019 I'm trying to turn off a layer "ADA Door Swing" of objects within a block but can't seem to get it done. Is this a setting or a limitation? The block ignores the layer state. Block Layer Test.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted April 18, 2019 Share Posted April 18, 2019 try ....... Unblock>turn off>reblock (if needed) Nested Blocks hold the Layer they had assigned when the block was made ...... Link to comment Share on other sites More sharing options...
ACADuser Posted April 18, 2019 Author Share Posted April 18, 2019 I'll send a feature request. BTW I have about 10 similar blocks. Thanks Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 18, 2019 Share Posted April 18, 2019 A couple quick tips Alan, Instead of trying to turn the layer off, consider just changing the line style to the Invisible line style for the layers you don't want to see. You can optionally convert all those CAD objects to molding polylines (no molding assigned) and then create an Architectural Block instead. Then you can do what you're trying to do. Block Layer Test 2.plan 1 Link to comment Share on other sites More sharing options...
ACADuser Posted April 18, 2019 Author Share Posted April 18, 2019 Good tips Michael. I like the line type approach, you always surprise me with your solutions. Thanks Link to comment Share on other sites More sharing options...
