Mardie Posted April 13, 2019 Share Posted April 13, 2019 I am in Kitchen Bath layer set, NKBA dimensions, defaults for 1/16" is checked, but drawing is showing in feet and inches instead of just inches? Never had this happen before in x10. Anyone else have this problem? Solutions? Link to comment Share on other sites More sharing options...
MarkMc Posted April 13, 2019 Share Posted April 13, 2019 Layersets only control what layers are active/viewed, the do not dimension defaults. Either use NKBA annotations, kitchen and bath plan view, or just the dimension set to NKBA dimension default. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 13, 2019 Share Posted April 13, 2019 1 hour ago, Mardie said: I am in Kitchen Bath layer set, NKBA dimensions, defaults for 1/16" is checked, but drawing is showing in feet and inches instead of just inches? Never had this happen before in x10. Anyone else have this problem? Solutions? It sounds like the Primary Format has been changed from " to '-" ( inch to Ft-inch or Ft) in the NKBA Dimension default ( same tab as where the accuracy is set to 1/16th) Link to comment Share on other sites More sharing options...
MarkMc Posted April 13, 2019 Share Posted April 13, 2019 43 minutes ago, Kbird1 said: It sounds like the Primary Format has been changed from " to '-" ( inch to Ft-inch or Ft) in the NKBA Dimension default ( same tab as where the accuracy is set to 1/16th) that's odd- mine are fine and I know it did not change them since I never use them as I have my own. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 13, 2019 Share Posted April 13, 2019 2 hours ago, MarkMc said: that's odd- mine are fine and I know it did not change them since I never use them as I have my own. I was assuming Pilot Error of course ..... Link to comment Share on other sites More sharing options...
