jpdesign Posted April 5, 2019 Share Posted April 5, 2019 Hello, How to fix the problem where the wall circled in red? its lower half is interior and upper exterior. Thanks, Josh Link to comment Share on other sites More sharing options...
Chopsaw Posted April 5, 2019 Share Posted April 5, 2019 Try in Wall specifications Roof > "Lower Wall Type if Split by Butting Roof". If not post your plan file for professional help. Link to comment Share on other sites More sharing options...
Kbird1 Posted April 5, 2019 Share Posted April 5, 2019 7 minutes ago, Chopsaw said: "Lower Wall Type if Split by Butting Roof". That should do the Trick.... If the garage roof plane is Manual pull it back off the house wall too and then let it "re-snap" to the house.... M. Link to comment Share on other sites More sharing options...
jpdesign Posted April 5, 2019 Author Share Posted April 5, 2019 26 minutes ago, Chopsaw said: Try in Wall specifications Roof > "Lower Wall Type if Split by Butting Roof". If not post your plan file for professional help. Hello Chopsaw, Thank you so much to point this option out. I didn't know what the option "split by butting roof" for. Now I understand. Appreciate your help. Josh Link to comment Share on other sites More sharing options...
