Trying to get a 12x24 wall tile to offset in brick like pattern
hrdorlando
1 hour ago, hrdorlando said:
I have tried everything and watched every video available, but still can't get a 12x24 tile to offset into a brick pattern on a fireplace wall.  Any help is appreciated.  Thank you.
Are you talking about the Pattern for Vector View ?  that's fairly easy but for Standard View you need a nice square on Image with Grout lines to convert to a Material.
It maybe possible in the Dal Tile , Cactus Stone or other Tile Manufacturer Library to find one you can work with....
