Michael_Gia Posted March 23, 2019 Share Posted March 23, 2019 Are polyline labels locked to only one independent default text style? Example: If I create a "room polyline" and open it's "object layer properties" I get the two lines highlighted, one for the "polylines, labels" and the other is the specific layer that I have set up to change color, line style etc... I want to change the text style of the polyliine label but if I do this it will change the text style of ALL polyline labels used in the plan. How can I change the polyline text style only for that item? Link to comment Share on other sites More sharing options...
Chrisb222 Posted March 23, 2019 Share Posted March 23, 2019 16 minutes ago, Michael_Gia said: How can I change the polyline text style only for that item? We can't do it very easily. Please add your support to this suggestion: A method to accomplish it is described in that thread, but it's not easy. Link to comment Share on other sites More sharing options...
Michael_Gia Posted March 23, 2019 Author Share Posted March 23, 2019 thanks, will do!… I thought I was going crazy for a minute Link to comment Share on other sites More sharing options...
Michael_Gia Posted March 23, 2019 Author Share Posted March 23, 2019 1 hour ago, solver said: Text Box containing a macro. If I have a text box with a macro, then I can change the text style just fine for that text box, but how do I refer to my room polyline so I can display info about the room polyline? I can create a room polyline and use its object specific values but how can I get a random text box containing a macro to refer to those polyline object specific values? I know I can use a text box in a room to pick up room specific values but not the polyline values. Or is there a way? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 23, 2019 Share Posted March 23, 2019 Another thing I personally do sometimes is convert my polyline to a molding polyline (no molding) which gives me a second label layer to work with... Link to comment Share on other sites More sharing options...
Michael_Gia Posted March 23, 2019 Author Share Posted March 23, 2019 I can’t seem to use the new “perimeter” value for a standard polyline. It only seems to work for the room polyline. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 23, 2019 Share Posted March 23, 2019 A polyline has a perimeter attribute and has for a long time. A room also has a perimeter attribute now. If you want to use the perimeter of a room somewhere other than the actual room label though, you need to use room.perimeter. The latter will not return the perimeter of a plain old polyline though. It will return the perimeter of the room it is located inside of (if it is). 1 Link to comment Share on other sites More sharing options...
Michael_Gia Posted March 23, 2019 Author Share Posted March 23, 2019 13 minutes ago, Alaskan_Son said: A polyline has a perimeter attribute and has for a long time. A room also has a perimeter attribute now. If you want to use the perimeter of a room somewhere other than the actual room label though, you need to use room.perimeter. The latter will not return the perimeter of a plain old polyline though. It will return the perimeter of the room it is located inside of (if it is). Thanks to both of you. I get it now. Link to comment Share on other sites More sharing options...
