PBR'ing Give it Some Life
TheKitchenAbode
8 hours ago, TheKitchenAbode said:
Thanks Scott.
And for those Dog Lovers.
807932036_KitchenPersonsandKittyandDog.thumb.png.cf2a4d5fde9120333547a629fc9e5076.png
Your stainless steel and those seat cushions are just amazing.
My 24hr raytraces don’t even come close to your PBR’s!
I even watched all of RenéRabbits’s PBR session that Scott hosted the other day....
Thanks Michael. The techniques I am using are very similar to those used and demonstrated by Rene in Scotts PBR session. Rene did a great job highlighting the important techniques concerning lighting and material properties that can be used to improve the quality of PBR output. There is another aspect to all of this that is very difficult to explain/describe in absolute terms. How a material looks is not just in accordance to it's property settings, it's appearance is directly tied to the intensity and type of light(direct/indirect) that it is exposed to. For example, a material that you give a level of reflectivity to can only reflect if there is light striking it at the proper intensity and angle to be reflected, when setting a materials reflectivity you are really only giving it the ability to reflect. The same holds true for all of the other material property settings, the potential to appear rough, the potential to appear a certain color the potential to exhibit ambient occlusion.
This is why it is so important to first get your lighting properly set and balanced, each type of light sun, spot or point contributes varying degrees of direct and indirect light. Only once you are satisfied with the overall lighting should you then start reviewing the materials and adjust their properties so they appear proper under those lighting conditions. It must also be recognized that CA's PBR feature is not as sophisticated as other dedicated PBR programs so there is a limit as to how far you can push your material properties to get the look you want. More sophisticated programs allow you to force a material to appear a certain way regardless of what the lighting dictates. It's what we do in Photoshop, the pic straight out of the camera often looks dull/flat so in Photoshop we crank up the color saturation, adjust the exposure and gamma, add some sharpening and more, the resulting pic is now often greater than what real life would dictate it to be. Achieving a level of this is not impossible in CA's PBR but it's very challenging as it does not have these built-in control features.
    31389
    LeighSupplies
    LeighSupplies
  • Similar Content
    • By HelloNorden
      I've been working in Chief Architect x12 and just upgraded to x13. I hoped that the upgrade would fix this problem I working on.
      All of the walls are meant to be this warm wood tone. In pbr mode, the sloped ceilings are practically glowing and washed out. Some of the walls also have this super washed out brightness to them and occassionally I get a really grey wall as seen in the bedroom. In x12, that grey wall was showing as solid black. I can confirm that the wood on the walls and ceiling are all the same materials with the same properties. In the bedroom, all the lights are off while the living space lights are on, without it affecting the brightness. I've adjusted many of the lighting settings but everything else in the model is correct. Any ideas on how to fix this?
      Morgan
    • By EvanDesign
      I'm sort of new to CA and I've noticed that every time I go to set up my PBR it takes me FOREVER to get it looking good. This time however it has taken me forever to make it look good and I still cannot figure out how to fix this.
      Can someone help me figure out what I'm doing wrong, I find PBR to be so challenging.
    • By Renerabbitt
      X-13 RTRT, A breakdown from another forum in response to growing frustrations with RTRT.  (Items that are specific and searchable terms in CA have capitalized first letters)   There is nothing "wrong" with the new Astral PBR RTRT option. Better understanding of a modern rendering engine may help alleviate some issues. If you are feeling overwhelmed by this info you can always uncheck the option for the RTRT in your Rendering Techniques Tool. Feel free to contact me for support or advanced training. • In RTRT a low sample rate is used in live camera views. • For exported presentations images similar to a CPU-based RT, set your Maximum Export Samples as low as needed to eliminate fireflies and light leaks. The higher the sample rate in RTRT Rendering Techniques, the better the image(up to a point where benefits are negligible). This only applies to the Export Image Tool. • A sample rate in basic terms is the number of samples from a camera of a given Objects Material ID as it applies to the geometry of an object, including colors, lighting, shadows etc. The more times something is sampled the less aliasing there exists in a final image. • The more light exists in the scene the easier it is to Sample. • You must supply ample light in adjacent rooms for the RTRT engine to properly process and "trace" your scene. Devoid of light, your exterior will be overly exposed, your interior may be underexposed, and you may have fireflies or light leaks. • Ensure that your active Light Set is on and illuminating your scene, which is accessed a number of ways, one being the Edit Active View tool, in the Camera Panel, under the Lighting Section. • With ample lights, an interior scene Rendering Technique Options might have an exposure from .15-.35, a Maximum Sample Rate of 500-1500, a Brightness between -10 to 0, a Backdrop intensity between 100-1000. This is not and never will be a universal setting, each scene needs adjustment according to the amount of light available to that scene. • If your scene is underexposed you may need to adjust your lighting including the lumens of your light fixtures. • Sun settings will do very little to help overexposure, underexposure, light leaks or any other trace related problems. This is the nature of a tracing engine. • Live view will always be of lesser quality than an exported image using the Export Tool(because of the option to change the sample rate.) • Typical problem causing issues: Caustics, Lights near transparent or translucent surfaces, lights of high Lumen values in one room juxtapose to lights of low lumens in an adjacent room. High resolution bump/roughness/normals maps in materials. These issues all cause difficult scenarios for attenuation and aliasing.    Some of the fixtures being used are not optimized for this new engine. Consider changing the material properties of any glass that is in close proximity to a light source. Changing the glass material of a light fixture that is turned on in a RTRT camera from Transparent class to General Material with high Transparency can yield much more predictable results. Same goes for situations when inside cabinet lights do not show up in RTRT behind Transparent Class windowed cabinet doors.   There is a lot more to this, you can have some success with this info, but barely scratches the surface. For some incredibly good generalized rendering info, read the Thea Render Manual(free online) It has some fantastic info in it that applies to all rendering engines. The following images are a RTRT with zero lights(screen clipped), an RTRT with lots of lights and same settings(screen clipped), and an RTRT export of the same scene The last image has the backdrop turned up since the sun direction is not illuminating the backdrop. Backdrop setting of 1000.
    • By robdyck
      A bit late in the day to be starting an old topic. What the heck is the deal with random wall lighting issues in PBR? I've tried every toggle and adjustment I can find but I can't get a couple of walls to display properly. It's clearly not a specific lighting issue because the problem is with a few walls. I recorded the PBR adjusting itself and somewhere along the way it gets it just right...but then just keeps on going. All I'd need is a slider tool so I could manually reverse / forward that process and then stop it where I'd like it.
      And while I was working on this I had an epiphany! I added a wallcovering to my offending walls, using the same material, and BOOM! They all play along now! This could possibly go in the 'tip and tricks' section.
    • By TheKitchenAbode
      Here is an easy quick way to add additional realism to your PBR model.
      - Go to Google maps and capture a street view, used snipping tool.
      - Place a Polyline Solid in the background and apply the captured Google Street view as a texture.
      - Scale and shift accordingly to get the right position and proportions.
      - Run a PBR with it and save pic. Run another PBR without it and save pic.
      - Drop both into Photoshop and erase out the unwanted Google Sky.
      1st PBR Scene - no Google Street view.
      2nd PBR Scene - with Google Street view.
      Final Scene - Combined with Google Street view sky erased.
