Roof help
Bdc2009
I agree with Eric, there is a learning curve where everything seems like it should work, but it just doesn't, then you learn a few techniques and you wonder whatever was the problem.  If you post your file, I will take a look at it and see if I can sort it out for you and let you know what I did to make the changes.
Not to take away from what these fellas have said, they're right, but that's a really easy roof using auto roofs.
Make sure you have Auto Rebuild Roofs checked.
Draw four exterior walls.
Draw three railings.
Select the two end exterior walls and two end railing walls and hit Change to Gable button, or open their DBX, go to Roofs and change to Full Gable Wall.
