KellySantaRosa Posted March 6, 2019 Share Posted March 6, 2019 I have lines where the second floor wall meets the upper floor wall. The walls should be in one plane. I tried realigning the walls to each other but no luck. Any thoughts? Ahmed Addition.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 6, 2019 Share Posted March 6, 2019 After you address the invisible wall situation Eric pointed out, open that upper wall, click on the Structure tab, and check Default Wall Bottom Height. Link to comment Share on other sites More sharing options...
KellySantaRosa Posted March 6, 2019 Author Share Posted March 6, 2019 Awesome, you guys are geniuses. Thanks kc Link to comment Share on other sites More sharing options...
Kbird1 Posted March 6, 2019 Share Posted March 6, 2019 1 hour ago, solver said: Is something missing? Isn't it weird the Invisible wall is there in Vector View? it shouldn't display anything should it ? even if Invisible walls are on in the ALDO.... M. Link to comment Share on other sites More sharing options...
