George Posted March 2, 2019 Share Posted March 2, 2019 Is there a way to change name of layout and linked plan at same time? I know that I can relink, but was hoping to avoid this, suggestions welcome Link to comment Share on other sites More sharing options...
agenoarch Posted March 2, 2019 Share Posted March 2, 2019 I'd like to know this also because it's a pain to relink files when you copy a layout Sal Link to comment Share on other sites More sharing options...
Evolution Posted March 4, 2019 Share Posted March 4, 2019 I don't think so. If I understand what you want to do? I usually open the layout then select the floor plan in layout which should open the link plan file. Then with both open, Save the open plan with a new .plan name, copy the name, then save the layout as .layout with the new plan name. Example gardenhouse.layout open select floor plan, click on it, then gardenhouse.plan opens. Now save gardenhouse.plan as maybe? gardenhouse2.plan, save the layout as gardenhouse2.layout. Is that what you are trying to achieve? More trouble than re-linking? 1 Link to comment Share on other sites More sharing options...
mthd97 Posted December 12, 2023 Share Posted December 12, 2023 On 3/5/2019 at 8:38 AM, Evolution said: I don't think so. If I understand what you want to do? I usually open the layout then select the floor plan in layout which should open the link plan file. Then with both open, Save the open plan with a new .plan name, copy the name, then save the layout as .layout with the new plan name. Example gardenhouse.layout open select floor plan, click on it, then gardenhouse.plan opens. Now save gardenhouse.plan as maybe? gardenhouse2.plan, save the layout as gardenhouse2.layout. Is that what you are trying to achieve? More trouble than re-linking? After searching for information, I found your reply and I might need to use your suggestion on how to link an old layout to a plan and save them. I asked the question on the 11th of Dec 2023. Thanks. Link to comment Share on other sites More sharing options...
rwdozier Posted December 12, 2023 Share Posted December 12, 2023 Many ways to skin a cat.... I do this to manually archive my CA editing progress. 123_house_01.plan 123_house_01.layout - linked to 123_house_01.plan I copy both the above .plan file and the .layout file as follows: 123_house_02.plan 123_house_02.layout - linked to 123_house_01.plan I then open 123_house_02.layout and manually link it to 123_house_02.plan. Really, the only thing I need to do manually is link the new .layout file to the new .plan file. I have a Windows Powershell script to automate the copy of the files. 1 Link to comment Share on other sites More sharing options...
stephanswim Posted January 12, 2025 Share Posted January 12, 2025 TtHANK YOU so much for this tip! You really just saved me a whole lot of time with this solution! Link to comment Share on other sites More sharing options...
