roofmolding
pokke700
3 hours ago, robdyck said:
You'll need to do much better than that to get any bites.
Not sure why it is so small here in the Chatroom Post the image goes Full size... I suggested he re-post over here
Hi Paul it may help if you use Google Translate on your Image and post this in the Q&A Forum ( Questions and Answers) but maybe this will help?
https://www.chiefarchitect.com/3d-library/index.php?r=site/detail/771
but you may need to draw your Own and use it as a Moulding
Paul,
je moet het zelf maken. Als ik zoiets nodig heb, heb ik een polylijn gebruikt. Maak het in hoogterekening. Hier is een voorbeeld:
you'll need to make it yourself. When i've needed something like that, I've used a polyline solid. Make it in elevation view. Here's an example:
