John_B Posted February 19, 2019 Share Posted February 19, 2019 I did a search through the X10 "HELP" documentation and this Forum but nothing indicates how to rotate a Space Planning Block incrementally rather than just in 90 degree block increments.....is there a bug causing these blocks not to incrementally rotate like any other object? I checked my defaults and it is set to CAD @ 15 degree increments. HELP!!! Link to comment Share on other sites More sharing options...
Richard_Morrison Posted February 19, 2019 Share Posted February 19, 2019 They should rotate incrementally with the transform/replicate tool. At least, they do in X11. Link to comment Share on other sites More sharing options...
John_B Posted February 19, 2019 Author Share Posted February 19, 2019 Thanks for the Reply Richard, that tool can rotate them but you must know the exact angle that you want....when dealing with an odd shaped lot, not a good way to do this lol! Link to comment Share on other sites More sharing options...
John_B Posted February 19, 2019 Author Share Posted February 19, 2019 Eric, another great idea but I'd like some rooms at a 45 degree angle as well! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 19, 2019 Share Posted February 19, 2019 Sounds like a case where you might just skip using the Space Planning Blocks. As with all automated features. They can only take you so far and they only work in so many situations. Link to comment Share on other sites More sharing options...
John_B Posted February 19, 2019 Author Share Posted February 19, 2019 I know Michael but I was hopeful that X11 would fix this! Hopefully they'll take a look! Link to comment Share on other sites More sharing options...
glennw Posted February 19, 2019 Share Posted February 19, 2019 Get one Space Planning Block to the angle you want by Transform/Replicate, or draw a line at 45deg and use Make Parallel/Perpendicular. You can then use Make Parallel and use the SPB or line as the reference. Once you have a couple placed, you can use Copy/Paste for more. Link to comment Share on other sites More sharing options...
John_B Posted February 19, 2019 Author Share Posted February 19, 2019 Thanks Glenn, guess I'm going to have to....just can't believe the Chief Guys haven't addressed this the simple way by allowing the rotate arrow to truly rotate like ever other CAD block. Everyone has been great pitching in, thanks guys! Link to comment Share on other sites More sharing options...
