bionical Posted February 10, 2019 Share Posted February 10, 2019 Is there a way to remove this line on the foundation wall? I assume it has to do with the brick as I do not see it when my main walls are siding If it for the brick above and has to be there it should at least be a dashed line Thanks for any help Link to comment Share on other sites More sharing options...
Chopsaw Posted February 10, 2019 Share Posted February 10, 2019 It might be possible to edit the wall definition but someone would likely need to take a look at a test plan file at least. Link to comment Share on other sites More sharing options...
bionical Posted February 10, 2019 Author Share Posted February 10, 2019 Yes it is the brick ledge, but it puts it in on its own My brick ledge is 0" Link to comment Share on other sites More sharing options...
bionical Posted February 10, 2019 Author Share Posted February 10, 2019 OK thanks Link to comment Share on other sites More sharing options...
joey_martin Posted February 10, 2019 Share Posted February 10, 2019 If the foundation wall is a pony wall, simply select to have the lower portion shown while in plan view. This will eliminate the brick ledge showing when you don't want it to. Link to comment Share on other sites More sharing options...
bionical Posted February 10, 2019 Author Share Posted February 10, 2019 Thanks Joe Link to comment Share on other sites More sharing options...
