kkdesign9
How to download NKBA Template
Recently upgraded to x10 (Interiors). Completed my downloads and, but don't see the NKBA plan or template. Any suggestions? Thank you.
File>Templates>New Plan From Template
It should be in the list.
Agreed, it should be, but not there. I might re-install and see what happens. Thank you
Do you have any templates there? I don't know what Interiors is supposed to have.
Yes, I believe the same ones as x10 Premiere less NKBA. I'm rusty with my skills, but I'll try to attach.
If you didn't uninstal x9, go to the x9 data folder and copy it from there to the x10 folder
2 hours ago, kkdesign9 said:
704952810_Templatescreenshot.thumb.jpg.a6dc68fdcd82d5a06f2d5a3f3f6e78f9.jpgThese are the templates that show
Those are the CA "Styles Templates" , not the Standard Plan Templates.....
been I while since I did a Clean install but I believe in X10 it is now called the Kitchen and Bath Template.plan .......not    NKBA Standards.Plan ( x9 and earlier)
If you don't have it in the Chief Data Folder>Templates, Chief keeps a backup in the Installation Folder>Templates
eg : C:\Program Files\Chief Architect\Chief Architect Premier X10 (64 bit)\Templates
If you migrated to X10 , it should of brought the Templates forward though.
That seems weird...I'd have thought Interiors would definitely have NKBA annotations and Plans for sure....
    27602
    Floriance
    Floriance
  • Similar Content
    • By ChristinoDesign
      I am trying to dimension countertop to countertop aisle space in my kitchen and bath plan view, we typically show these for client presentation. I can't get the point to point dimension tool to snap to the countertop edge, unless I converted it to a custom countertop. Is there a setting I'm missing?
      Thanks
    • By JASInteriors
      I am trying to use the NKBA Auto Dimensions in Chief Premier X9 and was successful on doing so, but having an issue....I went up to the tab where it says 1/4" scale annotations and clicked the down arrow to show more options just like one of the training videos show and there are no other options. So I do not know where they have went and even went into the default setting and still no luck with more options other than the 1/4" scale.
      Also under the NKBA dimensions, will the program have an "alert" of somesorts to notify the designer if there is an issue with the layout or a pathway or anything like that. I have used 2020 design program in the past and it did just that.
      Thanks in advance,
      James
