sharpe_c Posted January 30, 2019 Share Posted January 30, 2019 Wondering how to create multiply siding types on wall. I would like to somehow apply vertical and horizontal sidings separated be trim boards across a wall, but done want to have to keep changing wall types as siding changes are typically near windows/doors. Link to comment Share on other sites More sharing options...
sharpe_c Posted January 30, 2019 Author Share Posted January 30, 2019 I am using X10 and attached is a pic of something along the lines I would like to recreate Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 30, 2019 Share Posted January 30, 2019 ...or polyline solids. Link to comment Share on other sites More sharing options...
tommy1 Posted January 30, 2019 Share Posted January 30, 2019 Looking at the picture, looks like wall types would work. Link to comment Share on other sites More sharing options...
glennw Posted January 31, 2019 Share Posted January 31, 2019 I would use Wall Material Regions the width of the doors/windows with Cut Finish layers if needed. Leaving the whole wall as a single wall type - easier to work with than a wall broken into different wall types. The vertical cladding above and below the window is a single WMR. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 31, 2019 Share Posted January 31, 2019 3 hours ago, glennw said: I would use Wall Material Regions the width of the doors/windows with Cut Finish layers if needed. Leaving the whole wall as a single wall type - easier to work with than a wall broken into different wall types. The vertical cladding above and below the window is a single WMR. Yep. This is a very good way to do it. Only time it really kinda sucks is at outside corners. I wish Chief would figure out a way to fix that issue. Link to comment Share on other sites More sharing options...
