edcsteve Posted January 15, 2019 Share Posted January 15, 2019 Does anyone know how to do this or has anyone done it? This is what my client sent me Thank you Link to comment Share on other sites More sharing options...
Kbird1 Posted January 15, 2019 Share Posted January 15, 2019 33 minutes ago, edcsteve said: Does anyone know how to do this or has anyone done it? This is what my client sent me Thank you With Polyline Solids would be my guess , and later export and re-import to make a Window Symbol if needed. I don't think the Window Tool will make that Shape , if that's what you were wondering. Don't forget to do your Forum signature at some point...... M. Link to comment Share on other sites More sharing options...
builtright3 Posted January 15, 2019 Share Posted January 15, 2019 I tried as a challenge and this is as far as I could get so far. Not sure where to go from here though. Need to somehow get it in the wall and put glass and grids in it. Link to comment Share on other sites More sharing options...
builtright3 Posted January 15, 2019 Share Posted January 15, 2019 Un-finished but here is my work if you can use it. Bring it in to your library to use it Heart Frame.calibz Glass Heart.calibz Link to comment Share on other sites More sharing options...
builtright3 Posted January 16, 2019 Share Posted January 16, 2019 11 hours ago, solver said: The hole in the wall is doable. Just need the window to fill it. So can you tell me how to make the hole? I looked and couldn't find any instruction on that. More importantly if you can tell where to find the instructions I can read it myself. Link to comment Share on other sites More sharing options...
builtright3 Posted January 16, 2019 Share Posted January 16, 2019 10 minutes ago, solver said: I don't know of any instructions, but here are the basics. Make a symbol, and set the Inserts Into Wall option. The symbol can be anything and to practice, the overall size is not important. Make the depth the thickness of the wall or more, and make the Insert Depth at least the wall thickness. Place the symbol in the wall and take an elevation view. Move it as required, then click Edit Wall Cutout Polyline in the Edit Toolbar. This will allow reshaping of the hole, independent of the shape or the symbol. You just need to experiment to see how it works. For the heart shape, I used 2 symbols and made the holes overlap to get the 2 humps at the top, as I could not break the top of the box. Thank you! I will try it. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 16, 2019 Share Posted January 16, 2019 1 hour ago, solver said: I don't know of any instructions, but here are the basics. Make a symbol, and set the Inserts Into Wall option. The symbol can be anything and to practice, the overall size is not important. Make the depth the thickness of the wall or more, and make the Insert Depth at least the wall thickness. Place the symbol in the wall and take an elevation view. Move it as required, then click Edit Wall Cutout Polyline in the Edit Toolbar. This will allow reshaping of the hole, independent of the shape or the symbol. You just need to experiment to see how it works. For the heart shape, I used 2 symbols and made the holes overlap to get the 2 humps at the top, as I could not break the top of the box. It maybe in the Tips Forum, Michael (AlaskanSon) wrote a post or two about making the "Cutout Tool" to make using the Wall Layer Cutouts easier. @Alaskan_Son Link to comment Share on other sites More sharing options...
