DiscoveryDesign Posted January 11, 2019 Share Posted January 11, 2019 I am looking to create this builder added soffit under a pop-out. Any suggestions? Link to comment Share on other sites More sharing options...
DiscoveryDesign Posted January 11, 2019 Author Share Posted January 11, 2019 How do I add depth to the polyline solid? I have created the outline of the shape but don't know how to give it the depth needed to fill the space. Link to comment Share on other sites More sharing options...
CJSpud Posted January 11, 2019 Share Posted January 11, 2019 How deep is the popout? How will the soffit be built? Any load bearing issues or is it just curb appleal fluff? Link to comment Share on other sites More sharing options...
builtright3 Posted January 11, 2019 Share Posted January 11, 2019 You can also use the material region. Link to comment Share on other sites More sharing options...
builtright3 Posted January 11, 2019 Share Posted January 11, 2019 I'll elaborate; If you draw the cad line on the elevation view to your shape you can select your convert poly line tool and convert it to a material region and then set your depth and material and it will locate on the wall right where you need it. Very handy tool! Link to comment Share on other sites More sharing options...
GeneDavis Posted January 13, 2019 Share Posted January 13, 2019 The OP is using Chief 7. P'line solid is the best solution. Link to comment Share on other sites More sharing options...
builtright3 Posted January 14, 2019 Share Posted January 14, 2019 5 hours ago, GeneDavis said: The OP is using Chief 7. P'line solid is the best solution. good call! Didnt see that Link to comment Share on other sites More sharing options...
