ChiefuserMathews Posted December 3, 2018 Share Posted December 3, 2018 how can i turn off the window label displayed (not the window type). from the attached image, I want to turn off 2319PT and keep the window type W01 mage Link to comment Share on other sites More sharing options...
Chopsaw Posted December 4, 2018 Share Posted December 4, 2018 If I am not mistaken it is usually one or the other or none at all. Both is not an option unless you have some sort of a special window ? It appears that you have two individual windows there in you screen shot, or at least a Pass-Through and a window of which the PT will not appear on the window schedule as it is not technically a window. Somehow I thought that a Pass-Through could previously be put on a schedule but I could be wrong. You can suppress the label of the Pass-Through if that satisfies you situation for now. Link to comment Share on other sites More sharing options...
chief58 Posted December 4, 2018 Share Posted December 4, 2018 if that is a furred wall you don't have to put a window chief will cut the opening when you dsignate it a furred wall in the wall dbx Link to comment Share on other sites More sharing options...
Chopsaw Posted December 4, 2018 Share Posted December 4, 2018 Sorry I had to check my notes on this one but you can get a Pass-Through to show on the schedule or block it from showing by going to the Schedule DBX under the general tab and select "Object to Include" or Not Include listing. Ray it seems the walls need to be closer for the furred option to work. Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted December 4, 2018 Author Share Posted December 4, 2018 what do you mean my furred wall? its a basement concrete wall. the client wants to finish their basement to maximize the living area. to do that we have to add drywall, when I add a drywall in front of the existing window i need a pass through window. thats what it is. i found out answer to my issue. it was the label for the pass through window. which i suppressed the label. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 4, 2018 Share Posted December 4, 2018 14 minutes ago, ChiefuserMathews said: what do you mean my furred wall? If those walls are a little closer together you can set the interior one to be "Furred" and then in the window DBX Under the Casing tab you can set the Double Wall Options. Link to comment Share on other sites More sharing options...
ChiefuserMathews Posted December 4, 2018 Author Share Posted December 4, 2018 Thank you all for your replies and tips. Great job. Very good forum. Link to comment Share on other sites More sharing options...
