rockyshepheard Posted November 21, 2018 Share Posted November 21, 2018 Hi all, I have a roof which is almost correct except it is missing a small section of porch roof (first floor) between left side bump out and garage (see balloon). I added a room divider just below the balloon thinking it would simply add the missing small section of porch roof but instead it makes a much larger roof and forces the second floor walls to disappear. The file currently shows the missing porch floor and ceiling...to see the bad effect simply build the walls again. Would someone be so kind as to take a peak and give me their thoughts? Thanks and happy Thanksgiving! first attempt.plan Link to comment Share on other sites More sharing options...
tommy1 Posted November 21, 2018 Share Posted November 21, 2018 What about something like this? Manually edited. X10 first attempt.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted November 21, 2018 Share Posted November 21, 2018 1 hour ago, rockyshepheard said: Hi all, I have a roof which is almost correct except it is missing a small section of porch roof (first floor) between left side bump out and garage (see balloon). I added a room divider just below the balloon thinking it would simply add the missing small section of porch roof but instead it makes a much larger roof and forces the second floor walls to disappear. The file currently shows the missing porch floor and ceiling...to see the bad effect simply build the walls again. Would someone be so kind as to take a peak and give me their thoughts? Thanks and happy Thanksgiving! first attempt.plan Auto Roofs are Off Rocky , seems to build okay once back on , though you appear to have a few "extra" roof planes in there eg just to the left of the Balloon perhaps 3 there ? edit : almost forgot.....the circled 2 is an extra Room Divider Link to comment Share on other sites More sharing options...
tommy1 Posted November 21, 2018 Share Posted November 21, 2018 Made a small change. Moved front roof back to wall. first attempt.plan Link to comment Share on other sites More sharing options...
rockyshepheard Posted November 21, 2018 Author Share Posted November 21, 2018 Thank you Kbird1 and Tommy1. Tommy1..what did you do clean up wise. Can you describe to me or were there too many steps to note? Thanks all! Link to comment Share on other sites More sharing options...
tommy1 Posted November 21, 2018 Share Posted November 21, 2018 1 minute ago, rockyshepheard said: Thank you Kbird1 and Tommy1. Tommy1..what did you do clean up wise. Can you describe to me or were there too many steps to note? Thanks all! I will post a pdf of plan view on basically what I did. Link to comment Share on other sites More sharing options...
tommy1 Posted November 21, 2018 Share Posted November 21, 2018 This is basically what I did. Link to comment Share on other sites More sharing options...
rockyshepheard Posted November 21, 2018 Author Share Posted November 21, 2018 Many thanks! Link to comment Share on other sites More sharing options...
