Cherel Posted November 12, 2018 Share Posted November 12, 2018 Wondering if anyone could suggest a solution to why Chief is slowing down so much I can't even dimension as the pointer has a mind of it's own. Could it be my graphics card or is it the I uploaded the new 3d symbols. Has anyone else had this problem? thanks, Cherel Link to comment Share on other sites More sharing options...
Chopsaw Posted November 12, 2018 Share Posted November 12, 2018 Likely a combination of the high poly 3D symbols and possibly not having the latest greatest video card but that would be just a guess without knowing a bit more about the symbols and their surface counts and what else you have in you plan file as well as your computer specifications. Sometimes just a reboot will clear up an issue like that but is very easy to put too much detail into a plan file if you don't have the latest gaming type system. Link to comment Share on other sites More sharing options...
Cherel Posted November 12, 2018 Author Share Posted November 12, 2018 thanks for your reply .. I did reboot but still in slow motion.. I have loaded this design up with imported textures.. I might need to upgrade my system to cope. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 12, 2018 Share Posted November 12, 2018 Most of what you will find in the CA libraries is optimized to use in CA. However other sources such as the 3D Warehouse can have some very high poly symbols that are really not necessary in most situations. The other possibility is you may have just one corrupted symbol that is causing the problem. Link to comment Share on other sites More sharing options...
Cherel Posted November 12, 2018 Author Share Posted November 12, 2018 That could be why... I used some poetic licence to create what I wanted so I could I have probably corrupted it. thanks for your help much appreciated! Link to comment Share on other sites More sharing options...
Kbird1 Posted November 12, 2018 Share Posted November 12, 2018 CA doesn't like Objects with loads of Curves , this = high Polygon counts = high Surfaces = Slow So things like Toilets, round sinks , round towel-bars/warmers etc etc that are not optimized for CA can cause big Slowdowns Also, it's good to have your Forum Signature filled in, especially with the Software Version, and Computer specs See mine below in Blue for how to do that. If you don't see my Signature below then you have them turned off for the Forum, so you need to Toggle it on by going to the Upper RH Corner of this Forum Window ^^^^ and Clicking on your Username and making sure Signature is enabled (green) and then Add your Own Sig. too : UserName> Account > Signatures M. Link to comment Share on other sites More sharing options...
