Treehouse2339 Posted November 7, 2018 Share Posted November 7, 2018 I purchase site plans in DWG format. Initially they imported fine. measurements and text included. I must have changed a setting because I cant import with the text any longer. text is turned on in the options. anyone have an answer? Link to comment Share on other sites More sharing options...
Chopsaw Posted November 7, 2018 Share Posted November 7, 2018 Try the cad block settings as AutoCad guys seem to cad block everything for some reason. Link to comment Share on other sites More sharing options...
Treehouse2339 Posted November 7, 2018 Author Share Posted November 7, 2018 That doesn't work either... Link to comment Share on other sites More sharing options...
Chopsaw Posted November 7, 2018 Share Posted November 7, 2018 Could you post the DWG file ? Link to comment Share on other sites More sharing options...
madcowscarnival Posted November 8, 2018 Share Posted November 8, 2018 I've had some strange things happen due to the font used. In both AutoCAD to Chief and even other CAD to AutoCAD programs. We once had a PDF come in, could read the text on screen perfectly. When printed it turned into all emotes (maybe wingdings). Never solved that last one, made the clients bring in hard copies. Link to comment Share on other sites More sharing options...
