Wayne-Thurmon Posted October 24, 2018 Share Posted October 24, 2018 How can I turn wall Dimensions on so when I am placing walls I can see how long they are. Or when I click on the wall I can see what the distance is between walls. Link to comment Share on other sites More sharing options...
jbaehmer Posted October 24, 2018 Share Posted October 24, 2018 Make sure under your "view" menu, that you have temporary dimensions turn on. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 24, 2018 Share Posted October 24, 2018 25 minutes ago, Wayne-Thurmon said: How can I turn wall Dimensions on so when I am placing walls I can see how long they are Alt-Q ........... check the appropriate box ....... I would also recommend getting the Reference Manual and Tutorial Guide PDFs from the Website under Documentation. (scroll all the way down) 27 minutes ago, Wayne-Thurmon said: Or when I click on the wall I can see what the distance is between walls. Temporary Dimensions ...toggle On and Off .........see above..... or Hit F1 for the Help Menu M Link to comment Share on other sites More sharing options...
