Hartman Posted October 18, 2018 Share Posted October 18, 2018 Hello, I am running x5 and am having trouble getting the materials in a pony wall to show up. Any advise would be greatly appreciated. I have pony wall checked in Wall Specification and the lower wall type with aligning pony wall with outer surface and in default display. If I click materials box, pony wall is there with two drop downs the exterior surface and interior surface. Pony wall is not mentioned here, not sure if it is supposed to be. pony wall defaults are outer surface and show lower wall. my upper wall is siding, which is the only wall that shows up in perspective view. I have the lower wall as stone, but it does not show up in perspective. Link to comment Share on other sites More sharing options...
Hartman Posted October 18, 2018 Author Share Posted October 18, 2018 Link to comment Share on other sites More sharing options...
javatom Posted October 18, 2018 Share Posted October 18, 2018 Try clicking on the wall in question. open the dbx, go to materials and tell the wall exterior to be default. Link to comment Share on other sites More sharing options...
Hartman Posted October 18, 2018 Author Share Posted October 18, 2018 I can get only one siding to work. The pony wall will not show the material just on the lower part and siding above. Link to comment Share on other sites More sharing options...
Hartman Posted October 18, 2018 Author Share Posted October 18, 2018 Here is the materials settings. Link to comment Share on other sites More sharing options...
Hartman Posted October 18, 2018 Author Share Posted October 18, 2018 great, thank you. That worked. How do I fix the stone to have a shelf? Link to comment Share on other sites More sharing options...
Hartman Posted October 18, 2018 Author Share Posted October 18, 2018 Haddad porch stone2.plan Link to comment Share on other sites More sharing options...
Hartman Posted October 18, 2018 Author Share Posted October 18, 2018 Hello Solver, Trying to upload, not sure if it is working. Link to comment Share on other sites More sharing options...
Hartman Posted October 18, 2018 Author Share Posted October 18, 2018 upload Failed Link to comment Share on other sites More sharing options...
Hartman Posted October 18, 2018 Author Share Posted October 18, 2018 There is a problem processing uploaded file. Still looking for answer on why the stone is the same face as the siding above. Link to comment Share on other sites More sharing options...
Hartman Posted October 18, 2018 Author Share Posted October 18, 2018 Stone.plan Link to comment Share on other sites More sharing options...
Hartman Posted October 18, 2018 Author Share Posted October 18, 2018 Sorry, new here. Link to comment Share on other sites More sharing options...
Hartman Posted October 18, 2018 Author Share Posted October 18, 2018 How do I change the upper siding on front enclosed porch above the stone without affecting the stone and siding on the main house? Link to comment Share on other sites More sharing options...
Hartman Posted October 18, 2018 Author Share Posted October 18, 2018 Yes, Plus the stone is flush with siding. How do you get the stone to be wider than the siding above? Link to comment Share on other sites More sharing options...
parkwest Posted October 19, 2018 Share Posted October 19, 2018 Check in dbx that “main” wall align. I believe you have exterior set to align. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 19, 2018 Share Posted October 19, 2018 20 hours ago, Hartman said: Yes, Plus the stone is flush with siding. How do you get the stone to be wider than the siding above? Use Align Inner Surface on the Pony Wall Settings...the Ponywall is really thick.... Assign the Porch as a Porch in the Room DBX and I think you'll get the Warning about a Deck over a Living Space to stop too. Link to comment Share on other sites More sharing options...
Hartman Posted October 19, 2018 Author Share Posted October 19, 2018 Thank you Mick and David for the help!! Link to comment Share on other sites More sharing options...
Hartman Posted October 19, 2018 Author Share Posted October 19, 2018 If anyone has advice on how to just change the siding on the enclosed porch above the stone to a different siding like vertical siding? I keep trying to change it, but it changes the main house and garage siding. Link to comment Share on other sites More sharing options...
Kbird1 Posted October 19, 2018 Share Posted October 19, 2018 You need to make a copy of the Siding Wall Type and rename it , eg Siding _Vert. and then change the Siding Material to a Vertical Type from the Library, then change those 3 walls to the new Walltype. M. Link to comment Share on other sites More sharing options...
