basketballman Posted October 5, 2018 Share Posted October 5, 2018 I know I am probably missing a setting ?? I can post plan if required ... Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 5, 2018 Share Posted October 5, 2018 Of course, you are "missing a setting" that solves just about any and every problem there is. But what, exactly is the problem you have posted to solve, what is wrong, exactly? DJP Link to comment Share on other sites More sharing options...
basketballman Posted October 5, 2018 Author Share Posted October 5, 2018 No floor framing .. Link to comment Share on other sites More sharing options...
DavidJPotter Posted October 5, 2018 Share Posted October 5, 2018 59 minutes ago, basketballman said: No floor framing .. Than check "Edit - Default Settings - Framing" and also the "Structure Tab" of the "Room Specification Dialogs" where the framing is missing. You also make sure that that named layer is "on" in the "Display Options" dialog for the camera set you are using to view the results. It really cannot be anything else. DJP Link to comment Share on other sites More sharing options...
basketballman Posted October 5, 2018 Author Share Posted October 5, 2018 Plan file enclosed; Whoever can solve will be nominated for Chief Guru status ... FLAMINGO_FLOOR_PLAN__Revised_10-5-18.plan Link to comment Share on other sites More sharing options...
javatom Posted October 5, 2018 Share Posted October 5, 2018 Open your room DBX and set the floor structure to default (do this for every room). Open "build framing" and tell the floor to auto frame. They will appear. The items you are currently seeing as floor joists are just cad boxes. Link to comment Share on other sites More sharing options...
javatom Posted October 5, 2018 Share Posted October 5, 2018 I did a quick version of it. Link to comment Share on other sites More sharing options...
basketballman Posted October 5, 2018 Author Share Posted October 5, 2018 Thank you, JavaTom , or should i say Chief Guru ... Link to comment Share on other sites More sharing options...
