specop Posted August 27, 2018 Share Posted August 27, 2018 I have a building that I am fixing up. One part of the building is 8" lower then the rest. So I solved that by making a separate room. But I am trying to make a ramp connecting the two. The ramp will be on the higher side and I will need to cut the slab. How do I set that chief architect. I cant see to get it to go into the floor. Thank you 1 Princetn _8 (3)2.pdf Link to comment Share on other sites More sharing options...
DavidJPotter Posted August 27, 2018 Share Posted August 27, 2018 Every object of whatever type has a dialog box. Those dialog boxes allow you to do whatever that object is preprogrammed to do, have a look and by doing so you can answer your own question easily, just look and see. DJP Link to comment Share on other sites More sharing options...
specop Posted August 27, 2018 Author Share Posted August 27, 2018 I went through the dialog box, which option is it? Is it the base height? Thank you Link to comment Share on other sites More sharing options...
Kbird1 Posted August 27, 2018 Share Posted August 27, 2018 You may need to make a room with invisible walls ( unless existing room is one big ramp?)and then make the room Open below and then add a ramp as a Ramp alone will not cut the floor slab out for you. Use the windows Snipping tool to post images direct to the thread please , pdfs mean we need to download them and save them then delete them... Also, it's good to have your Forum Signature filled in, especially with the Software Version, and of course a real Name is nice too .............. See mine below in Blue for how to do that. If you don't see my Signature then you have them turned off for the Forum so you need to Toggle it on by going to the Upper RH Corner of this Forum Window and Clicking on your Username and making sure Signature are enabled (green) and then Add your Own Sig. too : UserName> Account > Signatures M. Link to comment Share on other sites More sharing options...
specop Posted August 27, 2018 Author Share Posted August 27, 2018 Thank you. Ill adjust my signature shortly. The problem with doing it as a separate room is that the way the rooms overlay and the windows. See the attached picture. The Area in green is one high, the areas in orange are 8" lower. The red area is in the green area (the higher hight), but it that is where the ramp it. It goes down for a bit and then there is a landing that is equal to the lo wer level. As you can see there is a window along the ramp so I am not sure how to have it separate as a separate room. Thank you Link to comment Share on other sites More sharing options...
Kbird1 Posted August 27, 2018 Share Posted August 27, 2018 Post the Plan ( make sure closed in CA 1st or it wont attach ) and I'll have a quick look but am thinking what I suggested should work.... what version of Chief are you using? different versions require different answers which is why we like the Signature filled in too. M. Link to comment Share on other sites More sharing options...
specop Posted August 27, 2018 Author Share Posted August 27, 2018 I am using x10 (I just adjusted my profile). Here it is attached. Thank you very much door missing.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted August 27, 2018 Share Posted August 27, 2018 If you did your Signature? you didn't enable Signatures for your Profile ...should go Green when checked as I don't see it.... or you filled in your Forum Profile Page Info and not your Signature perhaps under Account above? M. Link to comment Share on other sites More sharing options...
specop Posted August 27, 2018 Author Share Posted August 27, 2018 Sorry it was in my profile. I just did my signature. Link to comment Share on other sites More sharing options...
specop Posted August 27, 2018 Author Share Posted August 27, 2018 Almost. If you see the doorway to the left? (I circled it in this attached pic). The whole width of that door way is supposed to be a landing at the lower height. The ramp will start at the end of the doorway and go up from there. Thank you Link to comment Share on other sites More sharing options...
Kbird1 Posted August 27, 2018 Share Posted August 27, 2018 It works for me using your Plan You do need to make the Window a Doorway and You do need to make the Doors both -8" at the bottom (lowest Floor) Here is your Plan back door missing_MHD.plan M. Link to comment Share on other sites More sharing options...
specop Posted August 28, 2018 Author Share Posted August 28, 2018 2 hours ago, Kbird1 said: It works for me using your Plan You do need to make the Window a Doorway and You do need to make the Doors both -8" at the bottom (lowest Floor) Here is your Plan back door missing_MHD.plan M. Thank you very much. I didnt think of doing it that way Link to comment Share on other sites More sharing options...
