Wall tie-in not displaying properly in elevations
ACADuser
51 minutes ago, ACADuser said:
I get this a lot so would someone explain how I can fix/prevent this, please.
Thanks in advance.
North A-New.zip
It looked like a Floor structure/roof plane issue to me , so I unchecked  Hang floor platform above on wall and it fixed it
The Balloon Framing option only works if the above is unchecked ( as in Roberts pic ) , it doesn't fix it on it's own for me.. .
unchecked on the Main wall BTW :
looks like you may have some lost Electrical , looking inside the Roof Plane ..... I thought maybe there was a beam in that Corner , so pushed the camera through the wall an saw....
Thanks, fellas, the Baloon through worked, just wonder why it is necessary to do that for that for it to work properly.
Yes the electrical got messed up. I did alter the ceiling height at some point as I recall.
Is there any way to reset the electrical when that happens?
This is not the first time for that problem.
the Electrical ( lights/Fans) snap to the Ceiling (0" offset) and in this case I think your Manual Roof Plane has overridden the Room Ceiling Heights , do the wall go up to the Roof Plane? they don't appear to in the plan/camera view I took
must be the Order I did it I guess cos Balloon Framing with Hang on Wall... still enabled didn't fix it for me...
Mick,
The wall corrects itself when I check balloon through
But the electrical is a mystery.
I have moved to another plan file where I added the walls, door & windows for the next 2 units & after I checked the electrical & it is correct now.
Wish I knew what caused the electrical ceiling objects to jump up & now are correct.
Oh well, I have to move forward at this point.
Thanks for the input.
