JbeckWY Posted August 17, 2018 Share Posted August 17, 2018 I need to create a pole barn structure and found instructions in this forum for an older version so I am having a hard time getting the correct settings. When it tells me to change the default settings under General CAD Defaults, I don't see Fill New Framing Members box. Since this is the first step I assume I will have a hard time finding other settings as well. Can anyone point me in the right direction? Thanks! Link to comment Share on other sites More sharing options...
Chopsaw Posted August 17, 2018 Share Posted August 17, 2018 They moved that to a more logical place. Plan Defaults > Framing > Plan Display. If you run into any other issues post the link to the old instructions you are following and we can help update them for you. Link to comment Share on other sites More sharing options...
ShaneK Posted August 19, 2018 Share Posted August 19, 2018 Here is a wall type for pole structure, add interior layers if needed. pole wall type.calibz Link to comment Share on other sites More sharing options...
ShaneK Posted August 19, 2018 Share Posted August 19, 2018 Link to comment Share on other sites More sharing options...
ShaneK Posted August 19, 2018 Share Posted August 19, 2018 WARNING!!!! Nothing is easy and all projects require work. No one click and done,,,,,,,, with any CAD program!!! 1 Link to comment Share on other sites More sharing options...
Rustic-Cowboy Posted November 21, 2018 Share Posted November 21, 2018 On 8/17/2018 at 1:09 PM, JbeckWY said: I need to create a pole barn structure and found instructions in this forum for an older version so I am having a hard time getting the correct settings. When it tells me to change the default settings under General CAD Defaults, I don't see Fill New Framing Members box. Since this is the first step I assume I will have a hard time finding other settings as well. Can anyone point me in the right direction? Thanks! Did you find your way through? I am running into the same thing Link to comment Share on other sites More sharing options...
Chopsaw Posted November 22, 2018 Share Posted November 22, 2018 4 hours ago, Rustic-Cowboy said: I am running into the same thing What version are you running ? I think I posted for X10 above. Link to comment Share on other sites More sharing options...
