Aamir77 Posted July 16, 2018 Share Posted July 16, 2018 Hi, I have made a barn door with polyline solid and changed its material from concrete to glass. It is producing wrong imagery during rendering, if you see in plan view the newly created glass barn door is away from the furniture but in rendering view it is mingling with the interior furniture. May I know where I went wrong? pictures are attached herewith. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 16, 2018 Share Posted July 16, 2018 If a quick reinsertion does not fix that it should be sent in to tech support. Ctrl + X then Ctrl + Alt + V on the door and then maybe the chair ? Link to comment Share on other sites More sharing options...
Aamir77 Posted July 17, 2018 Author Share Posted July 17, 2018 I tried your way but no betterment. Link to comment Share on other sites More sharing options...
Chopsaw Posted July 17, 2018 Share Posted July 17, 2018 The really odd part is it is only affecting the one material type and not the whole chair, also the same material on the table top ? Could be a material definition issue and not a layering problem. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 17, 2018 Share Posted July 17, 2018 best to post the plan for stuff like this if under 25mb...just make sure the plan isn't open in CA when you attach it , as CA locks the file while open and it can't be uploaded. M. Link to comment Share on other sites More sharing options...
