DianeP Posted July 15, 2018 Share Posted July 15, 2018 My client is wanting the stairway from the ground level garage to the 1st living floor. He wants this stair to attach to a landing that is a step below where the door to enter the house is located. In other words, coming from the house to the garage, you would pull open the door and step down onto the landing and then follow the stairs down to the garage level. Is there a way to do this using the stairway and landing tools. I have always had a landing going between two sets of stairs, or have the floor being accessed provide a landing. Hope I have explained this well enough for you to understand. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 15, 2018 Share Posted July 15, 2018 Shouldn't be an Issue , the step down to the landing should be the same size as the standard Stair Riser Height. Though in alot of places you cannot have a Door open with a step down directly at the opening. If you Draw the Staircase and make it best Fit Floor to Floor the DBX will tell you the number of Risers and their Size , you can then uncheck Automatic heights and subtract one Riser and draw in the landing manually adjusting its height as needed. M. 1 Link to comment Share on other sites More sharing options...
DianeP Posted July 16, 2018 Author Share Posted July 16, 2018 Thanks Mick and Eric. I ended up getting the stair riser height like Mick said and then used Eric's method and lowered the room the same amount as the riser so I could use the automatic stairs. Link to comment Share on other sites More sharing options...
