Rytikom25 Posted July 9, 2018 Share Posted July 9, 2018 I currently have chief architect premier x10. The firm that I am starting to work for has chief interiors. Will I be able to open the plans in interiors that I create in premier and vice versa? I can't find information on this matter. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 9, 2018 Share Posted July 9, 2018 Call Customer Service and find out from the source. I work with several Interior Designers who use Interiors with no problems at all. DJP Link to comment Share on other sites More sharing options...
lbuttery Posted July 9, 2018 Share Posted July 9, 2018 I believe Interiors can open a Premier plan and probably even make edits except for features that Premier has that Interiors doesn't - those will be read only It is the same "logic" that applies to opening/editing Premier plans with the HD products but check with CA's tech support team to be sure Lew Link to comment Share on other sites More sharing options...
Rytikom25 Posted July 13, 2018 Author Share Posted July 13, 2018 Yes. I contacted them. No problem going back and forth between premier and interior. Currently using interior at work and premier at home with same projects. Thanks!!!! Link to comment Share on other sites More sharing options...
