farhighpb Posted June 29, 2018 Share Posted June 29, 2018 (edited) Hi folks i migrate from home designer pro to chief x10 thinking that i will have more control on the print quality of my layout. i tried many ways to print render view, plan, etc and never succeed to my standards. today i tried to print one of my layout directly to my large format Epson plotter which can print 1200 dpi image. the problem is even on laser printer and even if i play with the line weight the lines are always too larges..when i say to large it wayyyy too large ! You cant read the anything. the original model was build in home designer pro 2019. Is this the problem ? Do i have to send it to PDF and then print with acrobat ? It is frustrating that a software costing this much is so special when it time to print. Thank for your help house.zip Edited July 2, 2018 by farhighpb added zip file Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 29, 2018 Share Posted June 29, 2018 If you want anything more than guesses you should post both the plan and the layout. Link to comment Share on other sites More sharing options...
farhighpb Posted June 29, 2018 Author Share Posted June 29, 2018 sorry the file is 54 meg... Link to comment Share on other sites More sharing options...
Smn842 Posted June 29, 2018 Share Posted June 29, 2018 If that's not zipped you should be okay with if zipped as plans usually compress to around a third of the original size. Link to comment Share on other sites More sharing options...
farhighpb Posted July 2, 2018 Author Share Posted July 2, 2018 On 29/06/2018 at 1:37 AM, Alaskan_Son said: If you want anything more than guesses you should post both the plan and the layout. uploaded the file ! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted July 3, 2018 Share Posted July 3, 2018 Try this for starters: File>Print>Drawing Sheet Setup. Change your scale to something like 1/4 in. = 1 ft. Link to comment Share on other sites More sharing options...
glennw Posted July 3, 2018 Share Posted July 3, 2018 You need to post the .layout file along with the .plan file. Link to comment Share on other sites More sharing options...
