Adjusting wall heights
GMBKitchens
I'm having issues adjusting the height of an interior wall. Done it before using the cross section/elevation. But this time it's always the wall furthest back the one that gets selected. Even when it's not highlighted gray. On this picture you can see I have the wall I want to make it 45" height highlighted gray but it was the back outside wall where the door is the one that got adjusted. Am I doing something wrong that I forgot about?
1 hour ago, solver said:
Have you considered making it a railing wall?
This would be the easiest way and give you a wall Cap which you would get if you drag it down Manually.....
In the wall DBX  check the Railing box and set it to a solid Type if not already done and under Newel set the height to 45"
