scout1
dimensions on layer sets
say I am on layer set framing and I need to manually dimension a wall  can that dim
go to a layer called dimension framing then when I switch layer sets to say windows
can I use manual dim and that dim will go to say layer window dim.
  can I switch layer sets and Manual dim will switch to different layers
Yes.  That's exactly what Annotation Sets were designed to do.
Michael is correct but you will need to assign the Dimensions to the new appropriate Layer you create as you mentioned , it isn't automatic , otherwise they would all remain on the Manual Dims. Layer
    28292
    DJRobinson13
    DJRobinson13
