changing cabinet styles
BlueTree
Working on a plan, I set the cabinet default to match the kitchen cabinets.  Now all cabinets resemble the kitchen cabinets.  How do i change the cabinet door and draw style?  I know this is simple but can't figure it out.
You would need to select all the other cabinets (that you don't want to match the kitchen) and edit the parameters that are indicated as (D)
ie: Default
This is a problem when you change the defaults for anything in Chief, all object that are using the defaults will change - be careful.
19 minutes ago, solver said:
You place a default cabinet, change the door and drawer, then they change back to the default?
I would not change it back to the default since that will change the other cabinets. Place one cabinet, change it. Copy and paste if you need more.
OR
If all you are changing is style, wood and color you can just configure the cabinets, then group select and change what you need.
