EconBlueprints Posted June 1, 2018 Share Posted June 1, 2018 Everything looks good in plan view. When I do a front exterior elevation, the siding is missing from where interior walls intersect the exterior walls. The same thing used to happen in V9 and V10, but I was hoping it would have been magically fixed by now. So, lacking the magic Fix Chief Wand, how can I correct this issue? Thanks Lane Mt. View Plan File.plan Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 1, 2018 Share Posted June 1, 2018 When I suggest a workaround, I am often attacked for that suggestion, never the less, this is easily repaired using the "Edit Layout" line tool after sending a view to layout and wall poly-lines can be edited before sending to layout as well. I have seen this but not often and I usually just repair the walls so they properly close. without your plan to look at, I can only generalize. I do not expect Chief Architect to achieve any kind of Nirvana any time soon, so I just work with it the way it is. DJP Link to comment Share on other sites More sharing options...
VisualDandD Posted June 1, 2018 Share Posted June 1, 2018 Here is a quick vid with some ideas... 1 Link to comment Share on other sites More sharing options...
EconBlueprints Posted June 3, 2018 Author Share Posted June 3, 2018 Thanks for the advice, both worked. Lane Link to comment Share on other sites More sharing options...
