Landscaping bench...I'm stumped
DaliaSassoon
I'm stumped.  How would I create something similar to the picture below? I can't seem to figure out how to do it.  I don't even want the posts.  I just can't find a trick for making four perfect quarter circles in a stone wall type set up to place evenly around a firepit.
The hitch you may run into in using a railing wall outdoors is that you may need to create a room so you can control the elevation of the bottom of the walls.  Delete the floor layers or use them for the stone work. Create the openings in the wall with doorways.  You will also need two or more  wall sections to create a full circle.   Or you could temporarily make the wall not a railing and adjust the bottom height in 3D.
    32639
    DonahueC
    DonahueC
