SallyMac52 Posted May 31, 2018 Share Posted May 31, 2018 I just upgraded to X10 so this is probably a setting I must change. I tried the default settings and preferences and searched the tutorial and online for help, but didn't find what I need. I do not want my temporary dimensions to pick up the interior walls when I place my cursor on an exterior wall. Can anyone direct me to the setting I should use? Link to comment Share on other sites More sharing options...
BryceEngstrom Posted May 31, 2018 Share Posted May 31, 2018 Hmmmm....hadn't noticed this change in behavior before but you're right, something appears to have changed from X9. For a temporary fix, you can disconnect the interior wall from the exterior wall. But, this is something you might want to send in to tech support. Or someone more knowledgeable than myself might have a better solution. Link to comment Share on other sites More sharing options...
SallyMac52 Posted June 1, 2018 Author Share Posted June 1, 2018 Thanks, at least I know it's not just me. I'm hoping one of our experts will know how to solve this, if not I will send it to tech. Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 1, 2018 Share Posted June 1, 2018 The only controls that ever existed for Temporary Dimensions are found in "Edit - Default Settings - Dimensions - Temporary Dimensions" as far as preprogrammed tendencies are concerned. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted June 7, 2018 Share Posted June 7, 2018 On 6/1/2018 at 5:48 AM, SallyMac52 said: Thanks, at least I know it's not just me. I'm hoping one of our experts will know how to solve this, if not I will send it to tech. There is a Note in this week's Update to CA10 PDF that this has been fixed ....... fingers crossed .... 2.7 Dimensions • Fixed a problem that caused Temporary Dimensions along walls to stop at perpendicu‐ lar walls. 1 Link to comment Share on other sites More sharing options...
SallyMac52 Posted June 8, 2018 Author Share Posted June 8, 2018 Thanks Mick, hopefully this will take care of it. Link to comment Share on other sites More sharing options...
