BrettL Posted May 24, 2018 Share Posted May 24, 2018 Is there a setting I can change so that my dimensions will snap to the countertops (auto generated by the base cabinet) in plan view? Thanks Link to comment Share on other sites More sharing options...
glennw Posted May 25, 2018 Share Posted May 25, 2018 Maybe look at the dimension defaults? Link to comment Share on other sites More sharing options...
BrettL Posted May 25, 2018 Author Share Posted May 25, 2018 I have countertops checked in the defaults, but the dimension always grabs onto the cabinet. Link to comment Share on other sites More sharing options...
Michael_Gia Posted May 25, 2018 Share Posted May 25, 2018 Chief just has a hard time snapping to a lot of things. It’s random as well. Sometimes it snaps sometimes it doesn’t, regardless of dimension defaults. It’s worse in elevation or cross section views. Try snapping a dimension to a window height.... lots of aggravation and frustration. I’m forced to draw lines and set them at the height I need and snap to those lines. Although the story pole tool has helped greatly in this regard. Link to comment Share on other sites More sharing options...
dshall Posted May 25, 2018 Share Posted May 25, 2018 If you turn the countertops into custom countertops you should be able to snap to them easier. 1 Link to comment Share on other sites More sharing options...
