Architectural Block
Artisan_TH
Made a trailer with primitive shapes looks good in 3d Block it move it to the library
Pull it from the library to a plan in 3d one of the frame rails has dropped. I have not opened the block.
When I do open the block and select the frame rails each of them have the identical info in their dialog boxes
I have triple check everything.  ???
Link to 3d  https://3d-viewer.chiefarchitect.com/go?share=585097218277410
Instead of saving it as an architectural block to the library, try creating a symbol of it instead. Then save that symbol to the library. You'll probably have better results. I quit saving architectural blocks years ago for things like a trailer.
Have had this issue before, for some reason an element in the block will not adhere to it's height reference from the floor and defaults to absolute "0". Can only suggest making sure that all elements in the block are using the exact same height reference. If that doesn't work then as Tommy suggests you may need to convert this to a symbol. Just make sure to retain your block as you will need it if any future changes are required.
