Constantin Posted May 14, 2018 Share Posted May 14, 2018 Hello, I was wandering if any of you may have the Shear Wall CAD details (shown on some of the Chief sample layouts - see attached) to share with me. The Hold-Down and the Shear Wall schedules and the Portal Frame Elevation detail will give me a good place to start my shear wall design. Best Regards, Constantin A Link to comment Share on other sites More sharing options...
Ridge_Runner Posted May 14, 2018 Share Posted May 14, 2018 Those details appear to be using Simpson's products. They should be available from Simpson's site. I have used their CAD details before but they will need to be modified for your line weights, font, text size, etc. Link to comment Share on other sites More sharing options...
Constantin Posted May 14, 2018 Author Share Posted May 14, 2018 No, the plans are not available for download. I was actually browsing the net (including strongtie.com) for quite a bit, but I couldn't find anything. I was hopping someone may have a copy that would save me time building from scratch. Best regards, Constantin A Link to comment Share on other sites More sharing options...
rlackore Posted May 14, 2018 Share Posted May 14, 2018 Simpson has a plethora of details available for their lateral and uplift system components. Download this application guide, find the connection detail you need (eg D/21, etc.) then go here to download a dwg or dxf file. APA has details as well. Go here to search and download. Personally I'd run the numbers first to determine what the loads are, then design the system and find applicable products, and then lastly draw the details. 1 Link to comment Share on other sites More sharing options...
Constantin Posted May 14, 2018 Author Share Posted May 14, 2018 Thanks! Link to comment Share on other sites More sharing options...
atumbaga Posted July 26, 2023 Share Posted July 26, 2023 FIGURE R602.10.6.2 METHOD PFH—PORTAL FRAME WITH HOLD-DOWNS Link to comment Share on other sites More sharing options...
atumbaga Posted July 26, 2023 Share Posted July 26, 2023 On 5/14/2018 at 4:43 PM, Constantin said: Hello, I was wandering if any of you may have the Shear Wall CAD details (shown on some of the Chief sample layouts - see attached) to share with me. The Hold-Down and the Shear Wall schedules and the Portal Frame Elevation detail will give me a good place to start my shear wall design. Best Regards, Constantin A Expand did you ever find it? I am looking for it also Link to comment Share on other sites More sharing options...
robdyck Posted July 26, 2023 Share Posted July 26, 2023 Download the Chief sample plan for reference. https://cloud.chiefarchitect.com/1/samples/projects/lake-point/lake-point.zip?_ga=2.46161319.1253337191.1690228459-1226797399.1613256750&_gl=1*1v1ttcp*_ga*MTIyNjc5NzM5OS4xNjEzMjU2NzUw*_ga_06381P3JQ2*MTY5MDQxMTc5OC4xMS4xLjE2OTA0MTM3NTYuMC4wLjA. https://www.chiefarchitect.com/products/samples.html Link to comment Share on other sites More sharing options...
