HumbleChief Posted May 2, 2018 Share Posted May 2, 2018 I think I remember a thread or two regarding the subject and am working on an older house that has a parapet roof with the roof rafters running parallel to the baseline (versus the default perpendicular) and haven't found a method to reproduce the condition. I'm aware that Chief does not like to frame this way and can probably take care of any details/sections pretty easily but am curious about methods or workarounds. Oh yeah the roof is not flat but only 1/4" ft slope. Thanks Plan's attached ROOF_RAFTERS_1.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted May 2, 2018 Share Posted May 2, 2018 So you would like the pitch to run the long direction and the framing to run the short direction ? Looks like Eric solved it again. Your Signature could use an update Larry. Link to comment Share on other sites More sharing options...
HumbleChief Posted May 2, 2018 Author Share Posted May 2, 2018 16 minutes ago, solver said: You want the rafters running like this? You can tilt the baseline. Yeah that works. Never tilted a baseline before, never knew you could. Good stuff. Thanks Link to comment Share on other sites More sharing options...
HumbleChief Posted May 2, 2018 Author Share Posted May 2, 2018 Worked a treat, never knew Chief could do such things but a really nice fix. THANKS! Link to comment Share on other sites More sharing options...
bulmandesigns Posted January 17, 2019 Share Posted January 17, 2019 How exactly did you "tilt" the baseline? I seem to only be able to rotate it, which then changes my slope direction. Thanks! Link to comment Share on other sites More sharing options...
bulmandesigns Posted January 17, 2019 Share Posted January 17, 2019 Never mind, I found the option; for any future users: baseline angle under general tab in roof. This allows for a roof pitch opposite the baseline direction Link to comment Share on other sites More sharing options...
