EconBlueprints Posted April 18, 2018 Share Posted April 18, 2018 In a CAD view, I cannot pull a dimension between two sides of a closed polyline. When I disconnect all of the lines, the dimensions still do not show up. However, if I draw two separate cad lines, the dimension will show up between the two cad lines. Is there a dimension or polyline setting that will allow me to dimension between to lines of a single (or multiple) polylines? This was not any problem in my old Chief V10, but the new one has me outsmarted. On lots of fronts. Thanks in advance. Link to comment Share on other sites More sharing options...
tommy1 Posted April 18, 2018 Share Posted April 18, 2018 Are the sides you're trying to dimension parallel to each other? They might not be truly parallel to each other. Link to comment Share on other sites More sharing options...
EconBlueprints Posted April 18, 2018 Author Share Posted April 18, 2018 Lines are parallel. I am working around by drawing a line between the two lines I want to dimension, opening the line to see the length, adding arrows to both ends and manually typing in the line length. PIA at best. Thanks, Lane Link to comment Share on other sites More sharing options...
Richard_Morrison Posted April 18, 2018 Share Posted April 18, 2018 Please add your Chief version to your signature. I'd check "Locate Objects" for CAD under the Dimension Defaults. Link to comment Share on other sites More sharing options...
EconBlueprints Posted April 19, 2018 Author Share Posted April 19, 2018 it's checked. Link to comment Share on other sites More sharing options...
glennw Posted April 19, 2018 Share Posted April 19, 2018 Do you think that posting the plan may help? 1 1 Link to comment Share on other sites More sharing options...
EconBlueprints Posted April 20, 2018 Author Share Posted April 20, 2018 Glen, it may have, but I deleted it and started over. The plan was opened from my old V10, then saved in PremierX10. It was a small plan and I thought maybe the fact that it was from a previous version may have had something to do with the problem. When I duplicated it from scratch in Premier X10 I had no problems. Link to comment Share on other sites More sharing options...
