GeneDavis Posted April 8, 2018 Share Posted April 8, 2018 Version 10. I created these on the first floor and now want them to show on the foundation level 0. Trying to cut and paste in place, I get this message. And no layers are locked. Link to comment Share on other sites More sharing options...
crosscutter55 Posted April 8, 2018 Share Posted April 8, 2018 what if you put them on a seperate layer , maybe name them manualy drawn piers Link to comment Share on other sites More sharing options...
Kbird1 Posted April 8, 2018 Share Posted April 8, 2018 I think Piers need a Foundation Wall ( Containing Object?) and it be set to use the Grade Beams and Piers type......unless you draw your Own Piers with P-Solids? But not an error message I have seen before..... in the past I have drawn my own as the Grade Beam Default foundation was too limiting. M. Link to comment Share on other sites More sharing options...
GeneDavis Posted April 8, 2018 Author Share Posted April 8, 2018 I've got piers elsewhere on the plan with no issue. They are under the deck at rear. They are on their own layer, and the ones under the front porch are on their own separate layer. Sayers.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted April 8, 2018 Share Posted April 8, 2018 It is the issue I said above, the Foundation Piers need a ground beam or foundation wall then you can copy and paste (hold position) to level 0....but it doesn't look right , I'm not actually sure how you added Piers to a framed Walled like that.... so better to delete them and drawn your own like under the deck.... or copy and paste them from the deck... Link to comment Share on other sites More sharing options...
GeneDavis Posted April 9, 2018 Author Share Posted April 9, 2018 I had done the front piers as elements of a foundation wall. I changed them to slabs and all is well. Link to comment Share on other sites More sharing options...
