Stretching walls
mscpbd
Have any of you using X10 gotten THIS when you stretch a plan now? If I stretch it out the walls are no longer connected, if I stretch it in (like the attached) the walls stick out instead of moving with the new wall location.
Am I missing some new setting or is this a bug?
Debra
That behaviour TOTALLY depends on exactly HOW you move the wall.  Move the wall using Edit Area or the main edit handle and you should have no problem...accidentally group select the wall or use your center mouse button and one of the other handles and you'll have a problem.
If you're using dimensions to move the wall, make sure to select the Move Both Ends option and not the Move Object option.
If you just grabbed the Square Wall Edit Handle (where you clicked normally)  and moved the wall in ? that shouldn't happen.
So as Michael suggested it maybe How you did it , that is causing the Issue.
    30662
    VHarrisDesign
    VHarrisDesign
