Wall hatch fill default? Does anyone know where that can be changed?
zowie123
HI all,
Q: Wall hatch fill default?  Does anyone know where that can be changed?
No one at chief seems to know.  The factory default is 1?  Why? 1 barely prints. I've gotten caught on this several times. Is there a way to change the default? If not, perhaps chief make the default 5 or 10 so it's not overlooked when printed?
Thanks amigos!
If you don't want any line weights that thin, your safest bet might just be to change your line weights a bit and use the Advanced Line Weight Options in your Drawing Sheet Setup.  That way, even a line weight of 1 will print just fine for you.  Bad part is that you'll have to tweak all your line weights to accommodate the change, but the good thing is that you'll never have those thin lines that don't print again.
