Picked up a drafting job for a commercial building remodel
Cmd911
I recently picked up a gig redesigning a “metal building”.  The building isn’t and hasn’t been rented for some time and the realtor wants to build out for another possible client.  All good...  So, I’ve done a few home designs using wood and only one story. This building is metal and has multiple stories.  If anyone has tips or resources dealing with Chief and light commercial that would be beneficial.  I’d like to not screw this up and build good rapport with the customer and contractor.  TIA
All you need is Chief Premier and carefully set all Default Settings (take the time to accurately set these so they match the existing building) based on your on-site measurements, then carefully create your 3D model (.plan file) using your annotation sets for Electrical, Site Plan, Plan View, Framing and roof plan pages. It is the same as a residence only different construction methods and materials are used. Make sure you understand the plan and planning standards for this property and zoning setbacks, easements and other restrictions for this specific property to set design limitations. Depending on the scope of work your client wants you may need to engage a State LIcensed Structural Engineer to decide structural matters as a consultant once your plans are complete.
For CA, it is not an issue. This is a big box and drafting it is all the same as a small box but only bigger. For code issues, that is a different story. What state are you in? Is this getting a permit? Do you know what the exit requirements are for commercial? Fire codes, ADA codes, stair codes (different for commercial than residential). Commercial can be a beast of new information to learn.
I have personally used Chief Architect Premier X8, X9 and X10 to draw up plans in Michigan for post-framed buildings.  Some of these projects were light commercial.  Our engineer we often deal with has reviewed plans I drew up in Chief Architect and sealed them on more than one occasion.  In Michigan we use the Michigan Building Code for our commercial building code, which is derived from the International Building Code.  That document has become my new best friend along with the "A117.1 Accessible and Usable Buildings" when it comes to building codes that regulate commercial buildings.  Commercial projects can be a whole another ball game.   It's probably a good idea to have a copy of your jurisdictions commercial building code to reference.
    30642
    oppguenard1
    oppguenard1
  • Similar Content
    • By StaceyOes
      I have plans for what I what to do in our home, I’m looking to sit with someone in person, $125/hr, to put my plans into the software.I have pictures of want and my house's blueprints. Would love for someone to come to my home, but I will travel , even a few hours, to meet you - northern ky area. Stacey 859.308.8083
    • By Designer100
      Hi,
           I am trying to place columns and grid line with dimensions.
      I have to create on column circles and columns lines , then the dimensions will not place correctly to center usining manunel dimensinos (its leaves 12in on each side of column center lines.
      Chief Architect needs to be more friendly and have more commercial symbols and column lines to dimensions to them. They do have a commercial templet, but it does not have any of those.
      Plus they need commercial window details etc. I am donating this for a non-profit to design a rendering and another area added on the back of this building.I am donating a rendering of exterior to help them fund raise $300.000.00 (by December) to buy the exist. building and remodel adding finishes to look better and another 2,000 s.f. to it.
      Can anyone help me on working out the Grid center lines and will measuring correctly? turn on background and existing bldg. is under neath.
      Thanks,
      Newell
      CA Premier x 12
      Porter Road Floor Plan existing.PDF
      Existing Building remodeling.Addition.plan
    • By Adam_Gibson
      This is a fairly close representation of a John Boos E3S8-18-12R18 Stainless Steel E Series 74.5" Three Compartment Sink w/ Right Drainboard.
      3 bowl commercial sink.calibz
    • By MRCPOUSN
      How do you put a wall register  (HVAC) on a wall?
    • By steadijim
      I'm trying to work on an apartment that exists over two levels. They're not a whole floor apart but you go down some stairs to the back of the apartment so it sits about half a floor lower where the kitchen and bathroom are. Is it not possible to use this app for this?
