ComputerMaster86 Posted March 5, 2018 Share Posted March 5, 2018 I don't think it can be done but, is there anyway to have a watermark that has two lines of text? This should probably be in the suggestion forum. I like that chief has this watermark feature but, it just seems so limiting. My PDF editor just allows me so much more flexibility, when it comes to adding watermarks and even multiple watermarks. I wish I could easily add a watermark inside Chief Architect that says... Not for Plans or Permits For Review Only Seems simple enough. Link to comment Share on other sites More sharing options...
glennw Posted March 5, 2018 Share Posted March 5, 2018 Lance, While you are waiting, you can use the Image option in the Watermark defaults. Draw some multiline text, do a screen capture of the text and use that as your watermark. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 5, 2018 Share Posted March 5, 2018 2 minutes ago, glennw said: Lance, While you are waiting, you can use the Image option in the Watermark defaults. Draw some multiline text, do a screen capture of the text and use that as your watermark. Same thing I have suggested to users as well. Only thing I would do differently is skip the screen capture step. Instead, just export picture directly from Chief with a transparent background... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 6, 2018 Share Posted March 6, 2018 By the way, this can also be done in Chief without using the watermark feature at all, and in such a way that gives you far more control and flexibility but it requires converting your text to polylines which is most effectively done in another app (one of the only things I use Sketchup for anymore)... Link to comment Share on other sites More sharing options...
